Hi, I need to run a cable from the driver seat (leisure battery) to the back corner (driver side) of my LWB twin slider T5 (to main fuse box).
I am currently installing Cali floor rails and will be building up the floor height, finishing with 12mm ply and altro.
Would it be ok to run the cable in trunking under the 12mm ply, or is that bad practice?
I could also leave a pull cord in case I ever need to feed another one through.
One concern is drilling/screwing into the floor in future, so would need to know where it runs.
If not, I assume I would need to drop it through the floor under the seat and then run in some type of protective trunking(?) under the van, bringing it up at the back corner somewhere.
Could anyone offer any advice?
Many thanks
Up through the B pillar and along the roof should be fine and then drop down rear corner
Thanks, will have a look. Might be trickier now the pop-top is fitted and carpet lined, but will see if I can get through there.
