Hi all just about to run the wires for my led lighting was just wondering what size/type of cable to use i've been told to use twin core 1mm was thinking of using flex does this sound good?
you must use flex in a van (solid core can break with vibration/movement) and 1mm cable will be fine as led's done use a lot of power.
use red if u r going to use any type of spade and best to use a ratchet crimper too . other bloke is right t a e could get brittle and also pain to work with in that sort of area
