Thats ok, happy to help.Nice one rexy baby!
No point in having 20A fuse between panels and controller as the panels will never develop enough current to blow it. All the fuse will do is add unnecessary voltage drop.Thats ok, happy to help.
I have a 20amp fuse between the panels and the controller, and the same between the controller and the battery, although i have 200w of panels to your 100, so this may need to be different in your case. (Please check as i am in no way an electrician) Battery is earthed to the seat belt lower mounting with 16a cable (my furniture layout isn't the norm) 500mm long.
All's been installed for around a month now and works well.
A fuse is NOT to protect the panel or the charger....it's there to protect the CABLE.No point in having 20A fuse between panels and controller as the panels will never develop enough current to blow it. All the fuse will do is add unnecessary voltage drop.
In order that the 20A fuse can protect the cable it needs some thing in excess of 20A for it to operate. A typical 100W / 18V solar panel has a short circuit current of about 6A which is the maximum current the panel can deliver and is clearly not sufficient to blow a 20A fuse. The controller will not be capable of delivering any current back to the panel. It is quite normal for the connection from a single panel to it's controllerA fuse is NOT to protect the panel or the charger....it's there to protect the CABLE.
Oops, my error, and your right T: the cable is 16mm not 16amps. Knowing my electrical limitations i emailed an expert with a detailed description of what i wanted/needed to achieve and went 100% with what he recommended, so am happy and safe.I hope you mean 16mm cable, and not the thin stuff "rated" at 16 amps!
Cable ratings are mostly done for mains voltages, and only concerned about the amount of heat they will withstand.
Voltage drop is the important factor on a 12 volt system.
Quite agree GazM, however stranded has a slightly higher resisitance than a solid core, the voltage is DC and not AC and they have different insulation properties. I was just pointing out the differences to domestic wiring and what those ratings are based on. If in doubt always go for higher and I agree copper over aluminium.A fuse is NOT to protect the panel or the charger....it's there to protect the CABLE.
If you don't understand electrics, please don't confuse people.
@SmileyT;
Doesn't matter how many strands the cable has...it's still 6mm csa. (extra strands only make it more flexible)
Voltage drop is the most important factor with 12 volts.....
Drop a few volts at 230, no problem, the cable just gets warm.
Drop a volt on a 12 volt system, and you are 20% down on power available.
I agree about the jump leads....but don't buy the cheap aluminium ones!
TOTAL BULLSH*T!!!!!In order that the 20A fuse can protect the cable it needs some thing in excess of 20A for it to operate. A typical 100W / 18V solar panel has a short circuit current of about 6A which is the maximum current the panel can deliver and is clearly not sufficient to blow a 20A fuse. The controller will not be capable of delivering any current back to the panel. It is quite normal for the connection from a single panel to it's controller
The controller is a "switched mode device"....basically taking the DC from the panel, converting to a square wave AC signal, and then controlling the width of the pulse to regulate the current/voltage.Or_GazM
For my education please could you explain the failure mode on a 100W solar panel that would result in a 20A fuse in the panel to controller blowing.
Forget the "Tri-Rated" part.So if I use 6mm tri rated cable I'll be ok?
Lecurie,So if I use 6mm tri rated cable I'll be ok?
