I'm in the process of planning my conversion of a LWB T5
I want to add the twin fresh water tank kit from CAK and also internally fit either a Webasto Airtop or Eberspacher Airtronic under the driver's seat...
Does anyone know if that's possible or will the front water tank end up in the same place that the heater exhaust/inlet pipes need to go ?
I'm not sure that the 22 litre skirt tank on it's own is big enough for our needs and don't want to fit internal water tanks so, if the front tank does "interfere" with the heater, are there any other options for a bigger tank, especially as it's for a LWB ?
