Hi guys, hoping you can help me out.
I have a problem with my T4 rear calipers in that the driver side rear is not engaging when i use the handbrake.
Now, i believe the piston to be seized as i fitted a new handbrake cable recently so believe that to be working. The only other thing i can think of is that maybe the mechanism on the caliper is seized that would operate when the handbrake is on.
Anyway - i am wondering if because the caliper will not engage (as opposed to binding) if i should rebuild the caliper, or replace it?
I have rebuilt motorcycle calipers in the past with good success, however i am concerned that due to the relative complexity of the calipers on the T4 that there may be multiple problems, or perhaps seized sliders causing my handbrake not to engage?
