1 - 12 of 12 Posts
sc vw customs 1.9tdi convert
think i bought one when i had piston seizing probs other wise i use a crowbar and block of wood.
thought the backs had to be winded back though.....fronts are easy like you said,g clamp i use.:ILU:
possible to do without the tool,just makes life a lot easier,2 mins easy in fact.:ILU:
You do have to wind in the backs. Using this tools I find makes it alot easier all round, means less swearing when the g clamp doesn't fit properly:)
exactly mate,been doing vw brakes for years and have always been meaning to by one,took the plunge last week,and well what can i say.....makes a easy job..ver very easy..A:
Totally agree there mate-
Just did my pads & disks (front & back) yesterday- spent an hour farting about with a key for angle grinder wheel then thought Boll:*x to this- nipped down to halfrauds, handed over £18 and took SECONDS (!!!!!!!) to wind in the pistons.
Well worth the money! Universal too- plate flips over to do smaller pistons.
Also used it for the fronts, using the old pad as a block to push the piston home.
A:
Just about to do mine as the backing plates are buggered....
Can any of you guys recommend a good upgrade for discs and pads, a reasonable compromise between performance, cost and lifespan?
Ta muchly!
Ta muchly!
GSF do Brembo/ Mintex combo for reasonable price (s'what i got).
VW dealers doing stock OEM cheapish too.
Shop around- plenty of decent prices out there but general rule- buy cheap (ie £45 full set of disks n pads off eBay) you'll prob buy twice (as in they wont last half as long)
Thanks "T4 VIRGIN".
I'll get me one and hopefully it will be as easy as doing the front ones then ....:D
cheers
Frank
Just a tail end on this - reading up on a previous thread re pad changing - I changed the front pads on my T4 last spring and felt the brakes were a bit spongy and just didnt feel right - after a good bleed they seemed ok for a week or so then went off again - apparently if you push back the pistons by hand it can feed pressure back through the master cylinder and damage the seals - makes sense now - thats what I,ve done - by using the wind back tool it moves the pistons back slowly and doesnt do this damage - also they reckon to crack the bleed nipple when doing this
1 - 12 of 12 Posts
