Van is 2.5tdi 1998 LWB. nearly 140,000
Story:
My van broked down end of last week on the way to work.
Its not far between home and work (Bristol to bath uni, 10miles or so) but with a steep incline near the end of the journey.
So I had just come up the hill, turned off the main road into the entrance to the car park when something sounded like it snapped.
The van died and slowly came to a halt.
I tried to turn it back over, it tried to turn but then stopped.
Next turn of the key just resulted in a click, wouldn't even turn over.
So called recovery and got recovered back to bristol, to a garage that I've used a few times before (normally good).
They have only just had a look at it, and phoned to tell me the bad news that my cam belt had snapped!!!
So basically they have just given me some options and I wanted to get some opinions from people off hear.
They have said :
1. try and replace cam belt, and see if it runs ok? £200 odd
2. Take the head off, skim valves etc, replace cam belt, tensionsers. £1000 +
Bear in mind I've had the van for less than a year, and bought because it had already had the cam belt, water pump, tensioners changed in late 2009 and hadn't done that many miles since it was changed. (have reciepts to prove it)
I'm gutted as do not have that sort of cash at the mo, need to get to work everyday and am off to thailand at the end of feb!
So what would you lot do???
HELP
Steve
Story:
HELP
Steve
