Hi all had auto electrician trying to see why camshaft sensor code still coming up as I changed it to try and sort it,he tested original and replacement both ok and only getting 2.5volts at plug.
He's had a look at autodata thingy and is trying to work out if it should be 5vollts via ecu or 12volts via fan wiring ,also after wiggling some of the loom the fan now comes on straight away like it did before I fixed the common snapped wire at front of van..
Any help gratefully appreciated
Sye :D
From memory the cam sensor will be 5v from Ecu and signal back to ecu, sounds like you have some loom damage in the engine bay, first place to look will be where the loom goes across the top of the starter motor through the wiring guide, quite common to chafe there.
