hi guys iim currently tinkering with my t4 i purchased not so long ago, having some issuses with the timing belt not running true
causing it to run again the outer casings and the crank pulley.
im running ot of things to check and dont seem to be getting any closer any ideas would be a great help
aja engine code, its a 2.4 non turbo, so when the vans running the cambelt isnt running central on the pulleys as if something is bent or not sat in line with the other pulleys causing it to rub on the cambelt covers ive check all i can think of that will cause it
