I'm going to be replacing my camshaft on my AXD t5 this weekend, and have a quick question:
I also need to set the injector clearance (previous mechanic did not do this and it is causing issues) - can I do this after I've replaced the camshaft and whilst the camshaft cover is off? i.e. before I've turned the engine over. Or will I need to put it all back together, check the timing and then take it all apart again to set the injector clearance?
I'll be taking photographs and have written out a sequence of works based on the Haynes manual section numbers etc, along with parts needed, sundry items and torque settings for each of the bolts so will post this up after the weekend when I know it's all correct!
