Hi, first time posting so apologies if I’m in the wrong category - I was washing my VW this morning and noticed a black circular ring on the drive... on closer inspection found it had come from the front inner passenger side wheel arch exposing a large hole. The drivers side has the plug still intact so would need a replacement as the passenger side doesn’t have an inner (just a donut ring found on the drive). The issue I have is I don’t know what these are called, can anyone let me know what to search for so I can get a replacement ordered (sorry if this is really obvious, but you don’t know what you don’t know) first pic is passenger side, second pic is drivers side (intact)
176645
176646
Spot on! I’ll measure the size and get some ordered - thanks for your help mate!
Full of Cr*p....
And then think about the fact that you need TWO replacement inner arches, probably the whole inner wing and A pillars replacing.....SORRY!
Full of Cr*p....
I see a LOT of rot/bubbling there.
I just did my wheel-arches and managed to make a hole big enough to get my fist in! (Just about where that grommet is).
Have a poke with a screw driver....
