just ordered my parts to do my belts over the weekend and parts person at audi says cant do just a crank seal you have to buy it in a unit for £48 instead of £16. also cant buy just a rocker cover seal you have to buy a full rocker cover "yes sir thats £70+vat :eek:
You tried GSF ? Im not sure on the 2.5 but when I did my 1.9 crank seal it was loads cheaper at GSF for the cast ally/seal unit than from a main stealerT:
I couldnt buy the rear crank seal on its own as its moulded into the ally housing.
Pretty sure you can get the rocker cover gasket on its own, again try GSF etc
Meithered to death
£11 from GSF,right about the cam cover seal it is bonded into the cover and is non replaceable on its own.It is re-usable though so it should not need an new one unless it has been damaged
