Ive got a side door off a caravelle,what sort of money are these worth? Would it be cheaper to fit glass to the original door or get the velle door painted. thanks :*
what its worth will depend on condition if you sell it with glass it will be worth more. have you got a picture
No picture,very slight crease near the bottom of the door, you have to look for it, rust on the inside of the door where it meets the sill, the door trim is ok and the window slides and locks ok , cheersT:
If your original door is in good order then fitting the 'velle window to it is an afternoon's work - use the 'velle door's window opening to make a template and see how its cut. They just bolt in so you dont need to buy anything and the jobs free! You can sell the 'velle door on ebay minus the window for a few beer tokens or offer it on here if you're feeling generous:)
There are several 'how to' guides on fitting windows dotted around the forum with all the advice you're likely to need but it is vital that you remove the old bonding and rebond the skins to get them flat when using caravelle sliding windows - you'll see what I mean when you take the one out of your door.....
