Hi all,
Just bought a 2013 caravelle.
The cupholders in the central table are different - I take it they should be the same.
I think a previous owner may have tried to use a diiferent one as works fine, but the other appears to get slightly jammed when you press it in & doesn't pop out when you press it in.
Are they easy to remove, and can I replace it easily, is I can get one off ebay?
