Anyone know how much carpet (m2) i'd need to
a) line ply pannels
b) line the rear metal work
c) line the inside door pannels in the front
I have found a place that does 2m x 10 m (20m2) rolls for £85
if 10m would do then 2 of us could go halfs?
10 meters x 2 meters is about the right amount for the job you need to do and youll need between 8 and 10 tins of high temp spray glue, providing your van is short wheel base, try megavanmats, he is very helpful and knowledgeable and if you order it all together I think the delivery is only £8. dont be tempted by cheap low temp spray glue as it will fall off in the summer.
I can do 10mx2m with 8 cans of high temp spray adhesive for £99.
CLICK
