Hi peeps
im just about to carpet the interior of my daybus but am usure of whether to carpet the existing grey roof cards or to do them in ply,
would be great if anybody has any info to let me in on as im starting in the morn !
cheers Ronboy :ILU:
I am going to do my roof linning in hardboard easier to use and will expand and contract better than ply I'm sure factory linings are also hardboard I think for the reasons I have given
Hope this helps good luck
Jay
Ps if there is nothing wrong with your existing just carpet over them you might need slightly longer clips
2.5 TDI 88 AJT
A little bit of hardboard advice,
If you can, get hold of some oil tempered hardboard. it's stiffer, more wear resistant and moisture resistant than the regular stuff. you can recognise it by it being darker as well.
You won't find it at B&Q or Wickes, probably best to try a timber merchant. It's not much more expensive but worth the extra.
I covered my roof panels in cream leatherette but found that it won't stich to the back ,so i used double sided sticky tape on the back .
