Hi all,
Since I got my T4 a few years back the central locking never worked. Now that I'm finished rebuilding the engine it's time to tackle the locks.
All doors lock with the key fine independantly but none lock together with key or fob. I've checked the fuse and its ok. When doing the engine I fixed all freys/cracks in all the wiring under the bonnet and in the drivers door.
Not sure what could be causing this now as none are working it must be an issue early in the circuit, any ideas?
Full of Cr*p....
It's not just the drivers door loom....if there is an error on any of the lock motors, it can default to having use the keys in each lock.
Common one is the slider...the contacts on the door or frame.
