I've just had a moment of realisation. After fitting the central locking motor in the slidy door on my T4, I've realised a need for some kind of electrical contact to get the power to the door motor when the door is shut.
Is there a VW part for this, or an aftermarket/alternative manufacturers part that can be used?
I'm off to do a search on here now, but if anyone can point me in the right direction, it would be much appreciated thanks!
Andy
That looks like it should do the trick, cheers. Did yours come with any fixings? I presume they just bolt to the sliding door and pillar with some CSK screws?
Andy
Should come with everything you need including template.T:
