Hi guys, my central locking has gone haywire ! if I lock using keyfob, all doors lock down bar drivers door and then unlock. If I use key in drivers door, all lock down and then unlock. The only way I can lock is to press keyfob while turning key in drivers door! I have taken drivers door panel off and changed actuator, I found sliding door rod to be stiff and so I fixed that, still no joy!
Discussion Starter · #2 ·
Problem Sorted! After sifting through every post with a combination of central/remote/locking/fault/up/down/ blah blah blah...! I decided to try what some members had said, i.e. try the bellows/gaiter which houses/protects the cables running from the body to the door. 5 minute fix!! There it was, my elusive problem, a cable cut in two from opening and closing the drivers door for ten years! I hope this info is good for somebody,
Thanks guys,
CaravellemanT:T:
