Hi all,
Got my new van with a couple of niggles, one being the drivers door pin dropping and locking every time I shut the door. So popped the door card off to see the central locking disconnected? So hooked it back on to find when I shut the door it would lock its self inc all other doors? Opens with the key just fine but then locks again, and also locks if I try to open the door?
And also the locks won't work with the button, get a red light flash on the fob?
Driving me mad as nearly locked out with engine running!
Cheers kris
It is the return spring in the lock that has broken. There is a thread on here about how to repair it.
I had a similar thing with y passenger door. the locking motor had got water in it and had shorted out. the PO had then just disconnected it. i connected it back up and the central locking went metal. new door lock motor and it was all sorted.
As the for the fob not locking the doors, try re-syncing it to the car.
Any idea wheres best to get one? Re syncing the key easy enough? :)
