Hi all, I would like to change my rear barn doors to a tailgate.
Is this possible and what parts do I need as well as the tailgate?
Any help gratefully received!!!!
Thanks Antony
jabby fingered, worn nubbed, ginger ninja
if you get in touch with trev (windwelder)
he can do the conversion for you, he will travel tooT:
See my build thread below, just done mine.
Too be honest its quite easy. Just make sure when you get your new door, you get absolutley everything. All the little screws for the damper mounts, the flat spreader plates on the back of the hinges, the spring loaded receivers, the striker plate etc
You will need riv nuts (m6) plus the tool for fitting them.
You will need at least one helper to lift the tailgate into place (they are very heavy).
Good luck.
