I have an MOT advisory on both rear left and right brake pipes corroded. Had a look underneath and it?s the pipes that go from the inner flexible hoses towards the front over the full tank.
Went to TPS to get a price for the bits and they gave me a printout with all the pipes on, the two pipes go from the inner flexible hoses at the rear just by the suspension mounts and the one from the RH side comes across to meet up with the LH side one just behind the fuel tank, then they run over the tank, in the printout there is then a joint and the pipes carry on forward to the bulkhead.
Not having a pit or lift I have had a crawl around underneath with a torch to see if I could see what is involved in changing them and right up to the point they disappear over the fuel tank seems straightforward, taking the plastic splash guards off and disconnecting them from the flexible hose, but the joint as it goes forward I can not see and seems to be somewhere over the fuel tank so I suspect I need to drop the tank to gain access.
What I?m concerned about is: Is the original pipe just one straight run from the bulkhead to the rear flexible hose and the ones in the printout are a mod and I need to either cut it and flare the front end piece in place or is the original a two piece pipe that I can just disconnect and replace the rear section.
Any help, advice, pictures of the pipes above the tank would be handy, before I end up out in the open (no garage to work in) with a disaster on my hands, as I believe getting the pipes disconnected around the bulkhead isn?t straightforward.
It?s on a 2007 T5 T32 TDi SWB.
