Hi guys
i have a 2.5tdi with pp and i have a really nasty squeeking noise sounds like i have run over a pigeon all the time so i have decided enough is enough and have ordered a new power steering pump. As i am not a mechanic can i ask are these quite easy to change by myself or do i need to book it in to the local garage.
And yes it is the pump thats at fault.
07415125940
Piece of proverbial Matt.
Drain it down by undoing the pipe at the pump end.
Remove belt then bolts then pump.
Replace with new and do it all up again.
Top up the res and recheck the levels later that day.
