1 - 11 of 11 Posts
if it's anything like my Corrado (which looks similar) you cant change the bulb. i ended up buying a whole new facia. I could be wrong tho someone will be along in a minute I:
after the info from Nelds i decided to attack it.
the white is bonded to the black and the bulb seems to be in some heat resistant cover.
ebay or stealers for a new panel.
Ok nothing available from the main dealer or on classic VW so it will be an Ebay job but then the build will be as old as mine was.
has anyone found a replacment or a bodge?
i did exactly what you did, got the uint open and tried all dealers for bulb. Ended up getting another unit from scrappy, which luckily lit up for the remaining time that i owned the car.
1 - 11 of 11 Posts
