Hi, the wee button won;t stay in on the cigarette lighter. Anyone know where I can pick up the lighter bit?
If you squeeze the little contacts at the bottom of the socket in an inward direction it should fix your problem, the socket is what holds the button in so you actually need a new socket if this doesnt work, the contacts in the bottom are bimetallic, so they expand and let go once the lighter is hot enough, if they get weak then the button wont stay in,
Do it with something non conductive or youll blow the fuse
