Hi all
I have a 2005 t5 Iv been having some trouble with a clanking noise sounds like some spanners hitting together when I go over some bumps or hot a pothole Iv changed the droplinks,and antiroll bar bushings but still have the noise any ideas as to what I should check next ????
Thanks john
Hi I imagine it's the standard one that comes with the van I bought the van new I'n nov 2005 it's a minibus shuttle/transporter
1.9 tdi
John
maybe the rear spring rubber mountings, they fall to bits quite often
Hi the noise seems to be coming from passenger side at the front ,Iv replaced droplinks,antiroll bar bushings,wishbone bushings and the noise is still there,Iv checked wheels for any loose play and everything seems tight no movement at all,what next???????
