Map sensor and Temp Sensor are the same unit.
I would guess ignition live or the earth wiring to the sensor is damaged somewhere.
As mentioned before the MAF wont give you limp home ever just general sluggishness.
Cheers Jez,
The 'sensor' on the inlet manifold obviously does both pressure and temp then T:
I can see it's going to have to be a professional that sorts out the wiring issues
Are there any simple checks I can do as an electrical biffer, gently part the conduit that feeds the multiplug to the sensor I suppose, are the wire colours standard? what colour should I be looking for? Is there a common earth and where is it?
so many questions and so little knowledge on my part LOL
How long do you think it would take a professional to sort it out? (I know, how long is a piece of wire), what I mean is, is it quite straight forwards to someone who knows what they are doing? ie, these places feed the sensor, it will take me about 2 hours to check all the possible places there could be a fault?
just so i can get the most info, here is the fault so far
intermittant limp mode (well, reduction in boost) If i turned the ignition off and then on, it would reset mostly.
I unplugged the multiplugs to the MAF and the MAP sensors (one has silicone grease 'cage mod' the other is clean)
I put the code reader on and got the following codes 17563 and 17569 (once I got 17965) then cleared them, started the van and rechecked codes, mostly the first two came back.
I changed the MAP sensor (pressure and temp?) on the inlet manifold feed pipe
Drove the van and it is in limp mode all the time.
Unplugged the MAF and drove the van, it felt exactly the same, plugged in the MAF again and the van is still in limp mode.
Checked the codes again and got the first two and 17552 (I cleared them and only the first two returned) Checked the codes on a snap-on checker, slightly more info and the 'big book of codes' pointed to the sensor or 'wiring'
Pooh!
Any advice appreciated.
Jez you say you are in Yeovil on Monday, Is your day filled already? LOL:
Chris
