Hi All,
I've recently heard a noise appearing (sometimes) when I apply the brakes. It doesn't happen every time, usually over long journeys. It does not happen at speed, usually under 30mph, but as I apply the brakes a split second after I've pressed the brake a "clunk" will happy. It sounds like it is coming from the brakes. However, it doesn't happen every time.
Doesn't feel any different when braking, and brakes still work fine. Any ideas? :*
Many thanks.
Bottom balljoint perhaps?
You would be best to jack it up with a wheel off and inspect each side for anything worn/loose/perished
