hi newby here
my 2012 t5.1 developed a weired fault .turned on after driving fine made a crunching sound turned off ... when back on clutch bite point and clutch was further down than usual ...clutch only done 62000 miles! .. could be slave cycler no leaks or dirty brake fluid .. pulled clutch back up to normal position seams to be ok but the display that shows current gear and then if you need to change up or down also stopped working
any one got any ideas??
cheers for the help
