I have a combi cool fridge (Top opening type)
Anyone else have one of these? I usually run mine from hook up or gas. Anyone use there's on 12v? How long should it run from a fully charged 11oA Battery?
Guy
Hi mate not sure about this but i have a top opening cool box similar to yours mine is three way to, 12volt 90w 7.5amp now i think you divide 110 by your 12v amperage in my case 110/7.5 which in theory should run forabout 15 hrs but not surePerhaps someone on the forum could confirm. hope this helps
you also need to bear in mind that the heater on the fridge wont be on all the time as it will out on thermostat,a compressor on a domestic fridge only runs about 1/3rd the time. i would guess for a 3 way about 1/2 the time, so maybe double the hours on the battery:)
works out around 7.5 amp hour. so 110ah devided by 7.5 gives 14.6 hours but remeber that would be a fully ran down battery. so really to stay above the recomended 40% low your only going to get around 8.8hours
hth
ian
