Ive had the t4 about a week now and i noticed saturday that it was dripping coolant from one of the pipes. its the pipe which go's from the plastic bit up to the left hand side of the rad. I think its the Jube clip its been put on to tight and over time has worne into the pipe. when i sqeeze the pipe under pressure it leaks from where the Jube Clip is. Ive moved the pipe up the plastic bit (UNDER THE ENGINE) up further and tightend the clip an then slackend it slightly. but its still dripping. nonthing to the extent of the first time but its leaving a small patch on the ground each night the diameter of a pint glass. I guess its the pipe which needs replacing?
could anyone body give advice
thanks nafe
