Hi guys,
My 07 174 Kombi has been A1 since i've owned it 35000 miles.
I'm probably panicking over nothing but my only concern is that I'm certain it used to run the cooling fan after switch off on hot days for a number of seconds but now it doesn't seem to run the fan at all????
The temperature gauge on the dash is staying midrange but when you lift the bonnet you get a heat wave rise at you.
its still under warranty and I took it into the local stealer and they ran it through diagnostics and said all is well with it and its showing no fault codes but I'm certain the fan used to cut in some times!!!????
any thoughts appreciated
Landy
