1 - 14 of 14 Posts
Hi guys,
I've uploaded a couple of vids to youtube of my smokey engine.
Since taking the vids, I have set the timing with a dti gauge to 1mm and it's spot on, but I'm having the same smoking problems regardless of what I do with the timing.
On the second vid you can see I have some smoke coming from the oil filler tube :( Is this blowby? does it mean my rings are cream crackered?
Any comments would be much appreciated.
Btw, thanks to JonT4 for all your help so far T:
Ant
http://www.youtube.com/watch?v=2xm-ZZRboh8
http://www.youtube.com/watch?v=TrYq_OKhAmw
all you need to post the you tube widget is the bit after the '=' (square bracket removed from the start of each link so you can see what I have done)
YOUTUBE]2xm-ZZRboh8[/YOUTUBE]
url]http://www.youtube.com/watch?v=2xm-ZZRboh8[/url]
T:
Looks like a typical worn out engine to me.
I would consider getting a compression check done to be sure.
It's definitely blow by IMO mate It doesn't look as bad as some engines I have seen though.
The smoke out of the exhaust looks like unburned diesel. Does it stink and burn the hairs out of your nose?
It's probably a combination of worn injectors and poor compression like Zmok says get it compression checked.
Does the smoke coming out of the oil filler have a similar smell to the exhaust?
I think it's actually water vapour coming out the filler neck.. It condenses on the filler cap.
Not sure about it burning my nose.. Will check! :D
1 - 14 of 14 Posts
