Hi guys I have a Vw crafter which has no faults stored cranks but will not start I have had ecu tested no faults fuel side is ok new crank sensor fitted will start on easy start and the dyes .The only thing that I can see which isn’t working is if I in plug and sensor it reg a fault discount any injector dosent reg a fault I’m thinking maybe ecu although I had it tested has anyone had a similar fault many thanks Doug 2.5tdi Bjj engine code 58 plate
