Can anyone recommend a mechanic that is good with Crafters in the Northwest? I have ongoing high oil consumption that hasn't been solved with a rebuild and don't really fancy going to someone who'll keep guessing at the problem at my expense. I have spoke to a couple of vw commercial dealers who tell me that they've never seen high oil use on a crafter and its not a common problem.
Oil filter housing gasket went on mine! I took the gasket off and put a new home made gasket on as vw don't sell the gasket alone.
Guessing you don't have any visible signs of leaks?
How much oil is she drinking? They do consume a bit of oil these engines!
You have had an engine rebuild so I suspect they would have checked this?
No visible sign of a leak, its using around a litre every 3-400 miles no smoke, no oil residue inside pipework - more detail regarding the specific problem in my other thread.
