Hi owner of a 1993 vw t4 transporter 1998cc Petrol camper van started the van with the 230v still connected so leisure battery was charging hasn’t started since then rac could not sort the problem took there advise and change the ignition coil checked fuses . The green/black sensor wire is not receiving any signal, so the next step is change the cps but i can’t find it does anybody know what part of the engine it’s located cheers
I am not sure it has one! I think later petrols might have gone to a CPS but the early ones don't have one. The digifant ones have a hall effect sensor on the distributor that gives the timing information. I have the 5-cyl 95 and it has no CPS
