Vendor
As promised! CRVW 2011 Price List - updated to reflect VAT increases...
NOTE: A 5% DISCOUNT TO BE APPLIED TO THE PRICES BELOW FOR ALL FORUM MEMBERS!! T:
SWB SIDE UNITS / WARDROBE
A 420mm wide base single cupboard supplied with door (with door removed will accept integrated fridge (e.g. Nova Cool / Vitrofrigo / WAECO )
A 580mm wide sink base unit (fitted with fixed facia panels above designed to allow for depth of a sink/hob unit – not included)
A 450mm wide base unit with working draw above. Fixed panel with access from sink base unit – door available if not fitting a seat/bed)
A 600mm wide wardrobe unit with 2 opening doors – and access through rear gable
All cupboard and wardrobe units finished in black MFC
High gloss vinyl wrapped doors / draws / panels (choice of colours / finishes)
Worktop (choice of colours / finishes)
Soft close hinges (on all opening doors / draws)
Push button chrome/nickel locks (on all opening doors / draws)
LWB (only) includes a single wall unit if required
INCLUDES FITTING
£1330 (SWB) inc VAT
£1530 (LWB) inc VAT
(For furniture with our new Acrylic doors prices above plus £100)
SEAT / BED FACIAS – for Cannons Forge beds (if required)
Front and rear bed facia panels with openings as required
Finished in black MFC
High gloss vinyl wrapped doors (choice of colours / finishes)
Soft close hinges (on all opening doors)
Push button chrome/nickel locks (on all opening doors)
INCLUDES FITTING
Approx £260inc VAT (depending on number of openings etc)
TABLE SYSTEM
Table top (choice of finishes / colours)
Folding Table leg
Table sliding rail system
INCLUDES FITTING
£85inc VAT
ELECTRICAL PACKAGE
Leisure Battery
240V/12V Invertor (400W)
Consumer unit (fuse box)
240V RCD Hook-up (hidden)
Isolator switch (for all conversion electrics)
Power Switch (240v to 12v)
Split charge system (vehicle running)
Trickle charge system (mains hook-up)
2x 3-pin 240v sockets + 1x trailing socket (at rear)
4x independently switched ceiling mounted down lighters
Full loom / fuses with power for all appliances - fridge, water pump, hob, sockets, lights etc
INCLUDES FITTING
£650inc VAT
PLUMBING PACKAGE
25L Onboard water storage
Submerged electric water pump
Water feed pipes
Waste pipe (through floor)
Ventilation - gas / fridge (through floor)
Gas Regulator / feed pipe
Gas bottle retaining strap
INCLUDES FITTING
£110inc VAT
APPLIANCES
VitriFrigo Fridge
Fixed compressor, includes interchangeable door, magnetic closure, interchangable (colour matched) door panel. Single shelf with bottle holder.
Refrigerator Compartment Capacity: 38 litres
Freezer Compartment Capacity : 3.6 litres
INCLUDES FITTING
£495inc VAT
NOTE: WAECO fridge available for similar price…
Smev Sink / Hob
One piece combination sink/hob. 2 burner hob and left hand sink. 2 glass lids that work independently. Piezo ignition. Includes fold-down tap
INCLUDES FITTING
£270 inc VAT
FULL CONVERSION
If you supply a ply lined and carpeted van we can provide a full conversion including all the above (electrics, plumbing, appliances, furniture, seat/bed, facias, table). NOTE Plylining, carpeting and insulation are avaliable - see below!
INCLUDES FITTING
£3965 inc VAT (SWB) – high gloss
£4165 inc VAT (LWB) – high gloss
OTHER ITEMS:
Ply lining Kits: £225 SWB (excluding fitting)
£250 LWB (excluding fitting)
Floor Kit: £85 (excluding fitting)
Lay customers own floor £40 (vinyl cushion flooring)
Full carpeting: £425 supply and fit (includes metal work)
Insulation: POA
