totally agree with bacon trouses T: we bought van x, and can agree there was a lot of swearing coming from inside( which is why i stayed outside lol i wasnt allowed to help as leigh wanted to do it himself:* hehe)My Van-X curtains were a pain in the to fit due to them being 'universal' and not specific for the t4. You have to cut down the aluminum rails, try to bend them a bit at the ends and yes you do have to drill through the mounting side of the rail. I snapped a fair few drill bits and swore a lot but if you measure twice and cut once you should be ok. Btw get the premiums, as if the economy ones are as as poor as stopping light as their divider curtain are then you will be waking up earlier than planned T:
I have been reading about the Van X curtains and they seem very popular, however how easy are they to fit. What do you screw them onto? Do you drill holes straight into the metal below and above the windows?
cheers,
Popper kits on Ebay you say? I never thought about adding more but Ill take a ganderGreat curtains - quite a faff to fit, buy yourself a pack of 10 x drills from Toolstation/Screwfix - you'll probably need most of them.
Biggest problem I found was that bending the rail it deformed the track (squeezed it together) so the runners had difficulty passing that point.
Also if you want an ultra neat fit and block out any ****** of light - buy yourself another set of 10 x poppers and fixing tool of ebay.
Chris.
Definitely go for the Premium ones, you need an Electric drill and as others say stock up on high speed drill bits 2mm I think I used. Don't rush it. Its a faff bending rails to fit, I did succeed in rounding the ends a couple of inches up the sides which means the curtains open further. If you have carpet all around the window you need to keep your finger on the hole you drilled through or its extremely difficult to find when you try & put the screw in - if you have to take you eye off the spot! We did one window an evening it pays to take your time. Instructions were poor though. ie click on link to print out, then they say look at photos online before ringing us! BUT MUST SAY THEY LOOK GOOD.Hi,
cheers,
Good advice and I'm going to 'chip in' with something else I remembered.Definitely go for the Premium ones, you need an Electric drill and as others say stock up on high speed drill bits 2mm I think I used. Don't rush it. Its a faff bending rails to fit, I did succeed in rounding the ends a couple of inches up the sides which means the curtains open further. If you have carpet all around the window you need to keep your finger on the hole you drilled through or its extremely difficult to find when you try & put the screw in - if you have to take you eye off the spot! We did one window an evening it pays to take your time. Instructions were poor though. ie click on link to print out, then they say look at photos online before ringing us! BUT MUST SAY THEY LOOK GOOD.
They look pretty much identical to the 'Economy' Van-X curtains and they are around the same price if you include the postage. . How well do they block out light?I had similar problems with bending the track and it squeezing together but if you fill it with the curtain sliders before bending its easier, only worked that out on the last two!
And by the way I bought the veedub transporters ones and they were half the price and do the job pretty well!
