I have a 1998 T4 Multivan (Manual/RHD/2.5tdi), it has had a D5252 Volvo engine swap/transplant
It has done approx' 280k - but 75k on the 'new' engine.
Issue Symptoms
Started to be difficult to start after starting first turn of the key for months.
Difficult to start means, had to turn over for a few seconds before catching. This happened 3 times but it drove OK, then it cut out, took a long time to start, i kept the revs high until I got home. Left it idling on the driveway and it eventually, lost power and cut out.
It 'fluttered' a bit before stopping and using the throttle couldnt stop it.
Tried to start it again, took ages, but eventually started, left it idling and it cut out, after it had cut out I could hear bubbling coming from the tank.
Thought it might be a vacuum, so removed the fuel filler cap but exactly the same thing happened.
I have looked all over the internet, but nothing that can explain the issue.
Just got a new fuel filter today, so need to fit that to eliminate it.
Seems like a fuel delivery issue, any ideas what it could be, the bubbling after cut out seems a big clue (but only to someone that has seen it before!).
Has approx, half a tank of fuel.
I had recently topped up and added some diesel rhino too, if that could be a contributing factor.
Any suggestions welcome
Patrick
Issue Symptoms
Patrick
