Hi Guys doing my first conversion, I am considering getting the sergent unit, and have looked at the instructions and the only thing I cannot find is the location of the D+ engine running signal, I have seen it has been covered on the older models but could not fing anything on the facelift model - mine is a 2011 61 plate, any help gratefully received, cheers Jon
Thanks Steve mines a year older than yours 2011 so wonder if it will be the headlight switch or the relay ? also what amperage wires did you use ? many thanks Jon
If it's a 5.1 then I suspect it will be the same but easy to test with a bulb or multimeter. Cable amperage wise, it's a signal wire to the relay so 2-3 amps more than enough.
