Hi all just noticed I have dark small dots on all the felt were it covers the metal sections and there is a hole behind it it appears to be the air flow through the van when you have the heater on or a open windows trying to find a way back out there must be a vent at the back as in most vehicle has any one had the same problem if so we're did you put a vent in the inside ply boards...Thanks for any reply
Hi unfortunately I did not fit the carpet but if the air had had a path to escape I bet it would have helped as in fitting the carpet to the van this has made it air tight I'm going to fit a vent in the side panels at low level in the back and steam clean the carpet and see if that works worth a try
