Ran cable along top of windscreen behind headlining then down left hand 'a' pillar trim. Went under dash to fuse box under gear stick and piggybacked fuse 19.
Obviously be careful removing plastics but fairly robust.
When you take the dash side panel off (word of warning - passenger airbag plug needs to be unplugged, don't turn ignition on in this state as will throw up fault light and will need reset))Took about half hour to do. (2011 T5.1) T:
