checked big blue fuse ( on right hand side near bottom ) on fuse board for lighter , the one in passenger side low down on dash , fuse is ok , no power to lighter , the small blue fuse for other lighter is ok and lighter works ,
and now door windows stopped working , any idea where fuse will be to see if i have moved it while working on it , so i can test it
thanks lee
Special Rapporteur
You need to say what year your van is, as the fuse allocations changed a lot depending on year. If yours is 2010 onward then the cig lighter fuse will be under the passenger seat.
