Oscarli, I got this off the Audi-Sport forum I used to frequent, its about De-DPF-ing an Audi Tdi 170. There has been a few problems not unlike te T5 dpf scenario, whats your thoughts on the following:
"What i did as a first step , I took Dpf out cut it on 3/4 way round and using drill I removed charcol ( filter ) and then I weld it together and put back. Car had been running perfectlly...
As a next step I ordered milltek cut down pipe for 2.0 Tdi 140Bhp , drill three holes ( one for Lambda Sensor , and two for temp.sensors (before and after DPF) , and replaced "Dpf can" with it.
I didin't put pressures pipes back - is not nessesary - leave this sensor without connecting pipes into it - car will notice that is no different in pressure , so DPF is clean ! It does work - I have done 10000miles now driving like this.
Dyno Shown 15Bhp more after this mode done - U can hear turbocharger spin quicker, whisling louder , and U get better throtle respond.
I have also put bigger vacum silicon hose from N75 valve (boost pressure sensor) to Actuator ( was 3mm originally , and i got 5mm now )
At the moment I'm working on MAF sensor (mas air flow) and on APS (absolute pressure sensor) - Why ??
I ordered racing N75K valve from US ( Seat used it in Leon 2.0tdi WWRC Edition )
to lift boost up to 21-22psi - and those sensors are bringing a foult on as overboost.
I need few more days to get it solved , and I getting closer to the end. "
