1 - 13 of 13 Posts
G
Hi guys. As part of my refit I am adding an ICE system on the cheap. I am using bits and bobs collected off eBay. My head unit is a Sony Xploder cd/radio which is capable of handling 4x45w speakers. But I want to feed it through my Alpine 4/3/2 ch amp. In addition I want to power a sub woofer via another Alpine mono amp designed for a sub.
So I want:
head unit
10" sub via mono (Alpine) amp
2 dash speakers (Pioneer), 2 6" speakers (Pioneer) in the tail gate and 2 6x9 (JBL) speakers in the rear wheel arches all via a 4 ch (Alpine) amp. I might add another pair in the doors.
I also have another JBL amp which is rated at 2x40w or 1x90w, spare at the moment.
I want to power the lot off a utility battery fed via a VSR.
But how to lay this lot out? Can anyone mke sense of the above and suggest the best way to proceed?
Take the front out from the headunit to the jbl amp & run your dash speakers from that
Take the rear out from the headunit to the alpine multi channel amp to the speakers in the tailgate & wheel arches
Take the sub out to the alpine mono amp & run the sub off that.
Should do the trick nicely!
G
Discussion Starter · #3 · (Edited)
Thanks Zap, but the head unit doesn't have a Sub Out, so where should I take that off? Can I bridge it off of two channels from the Alpine multi channel amp?
G
I think I see a problem here. If I run the multi channel amp with a high pass filter to get the best out of the speakers, then I can't run the sub and mono amp from the same as they need to run as a low pass filter and won't get the necessary signal to do so because of the high pass filter.
So should I run it spliced from the head unit feed to the front speakers instead?
stop all the messing about, get down to any car spares or radio shop, get 2 high input to rca low output gadgets for £7 each, put these on the head unit speaker outputs, now they become rca output for amps front/rear, then use your rear rca output leads from head unit to power the sub, DONE T:
G
Discussion Starter · #8 ·
Thanks Smokey. The head unit has a DIN plug and speaker output for 4 speakers, so I assume I can get a plug with a DIN to RCA type connector?
G
Discussion Starter · #13 ·
Great thanks. So one of those provides enough outputs to drive one pair of speakers?
1 - 13 of 13 Posts
