does anyone have the definitive difference between the 174 AXE and 130 AXD engines??
as i understand it the block, head and camshaft are identical. the difference being the turbo, ECU and injectors. i have also been told the injectors are the same and the only difference is turbo and ECU
therefore a change in (injectors) turbo & a remap transforms the engine from AXD to AXE spec
can anyone confirm?
thx
Ross
The Know your T5 engine post has a bit in the self study vw doc that says the engines are identical except turbo and mapping!T:
The main differences i've found using VW parts Software ETOS (For a 2005 model) is
Turbo/inlet adaptor (garrett for 174 and 130autos, Borgwarner for 130 manual gearbox),
Flywheel/Clutch is different,
Software/ECU
WHERES DAZBOI????????????,
he'll be here soonT:
Software/ECU
Looking a bit more the injectors are different as well.
Can anyone else find any differences :confused:
research is ongoing...
so far web search has found
http://www.scribd.com/doc/47266666/2-5-TDI
which indicates the engines are identical - except for the Turbo and search onl VW parts confirms the turbo's are different
(which makes sense, why would VW/Audi build 2 different engines, esp as they have a history of having power variations of the same engine).
a call to Bosh technical support re fuel injectors
fuel injectors are different
to recap (so far) it would seem AXE and AXD are identical except for
Turbo
Injectors
ECU program
so the question are is this correct? and has anyone 'converted' and AXD to an AXE ??
Ross
