1 - 9 of 9 Posts
Hi
I'm looking at a few T4s for sale at the moment. What's the difference between a multivan and a caravelle and can all the rear seats easily and quickly be removed.
Thanks!
the multivans rear tripel seat folds down to become a bed. The caravelle only folds forward and tips to allow better access to the rear of the vehicle. Additional the multvan has a factory fit tabel which folds from the side and inward facing buddy seats .
caravelle generally has all forward facing seats, middle row quick removable rear not
multivan older vans have rear facing middle row ( buddy seats) and removal is quick , rear seat turns to a bed , rear not sure if its quick or not
newer multivans middle row seats can rotate etc
Beardy Bus Driver
Hello,
Apart from the cost I:
Is it worth it? For me yes T: But there's loads on here about that already.
Back on topic. As others have said the layout is different.
I thought the rear bench could be removed in the Caravelle? :confused: The Multivan's rear bench can come out, don't know how quick, as I've never tried. Most certainly a two person job. Multivan has curtains or should.
Good luck with the search.
Its about time I showed up
Wasnt the Multivan cheaper than the caravelle when new as well? Bonkers..
I wouldnt pay the difference personaly.. Just get a tidy caravelle for probably half the price and fit a bed if you want one :ILU:
our caravelle rear seats fold down completely flat, as do the middle, with a slight modification or addition this could very easily be turned into a bed. The middle row do come out, with a shove.....not too sure about the back as ive only had it a few months and never needed to take it out...yet:D
back seats come out in 5 mins; 4 bolts, 17mm socket
easiest removed forwards via side door, assuming middle row is out of the way
otherwise a 2 man turn and lift out through tailgate
1 - 9 of 9 Posts
