This is my first post so please excuse me if I have done anything wrong. I also just wrote an essay but it deleted when I uploaded pictures so this may be more concise.
I have bought a 2.5 TDI Auto on a 55 plate that was converted for wheelchair use, the lift and other features have been stripped back but not entirely, and some of the features remain, such as the electronic panels.
I bought the van knowing there was an intermittent fault where the engine will cut out, needing the van to be restarted and then it will run as if nothing has happened. I have read up about this and it could be a few things, this is a problem I will look in to another time, and it hasn't happened to me yet so I don;t want to guess as to what is wrong.
the issue at the moment is I have no power steering at low revs and I need an MOT very soon. I'm guessing the pump is on it's way out, but there are so many oddities with the van that I was hoping for as much advice as possible.
i have attached a few pictures, one is the steering fluid reservoir, not sure why it was changed to this does the standard one have a sensor?I can't get underneath the van at the moment, I am hoping it's just a standard pump would it be anything different?
One of the other pics is a part that is under the dash on the passenger side, the silver bar turns when I turn the steering wheel. I am assuming this has been moved over to there? Don't actually know what it is. Has cables running in the top.
One of the red lights on the pad lights up when I am turning and the power steering goes from being okish to being very heavy.
The battery cable is just loose in the bay, earths to the same one that is actually attached to the battery, no idea where the cable of it runs, only attache this so people can laugh at what I have to get done.
And general advice on if I can change those pads back to anything normal, most of the switches work with out the main panel so probably a case of a lot of hours stripping it back. It has an electric handbrake, how difficult would it be to put back in the mechanical? or at least wire up a different switch so I can remove the panel?
Same with the gear panel? It's not terrible but I would like to change it to something that resembles a shifter in its normal place. Any experiences with this? and what are my options.
...it wasn't any more concise.
Thanks in advance for any help.
