I've got a 2015 T5 campervan conversion and am planning to fit two AGM leisure batteries to increase my off grid power storage.
But I've been warned that I will also need to upgrade my alternator or run the risk of overheating in the alternator or regulator? I see that Californias come from the factory with 2 leisure batteries and a bigger 180W alternator, but is this to avoid the overheating problem or just to charge the batteries more quickly?
So can I stick with my existing standard alternator or must I upgrade?
Check the battery manufacturer's recommended maximum charging current, usually no more than approx. 30 amps for the agm 100AH leisure type, so at max recommended 30 amps x 2 = 60 amps, your alternator is probably 120 or 150 amps, so should easily cover the aux batteries and other usual vehicle needs.
It's hard to find that out it seems. Replacements from local suppliers range from 110W to 140W.
My batteries are both 90 AH.
It sounds like it wouldn't be a problem, though.
Your standard alternator will be fine. Bigger alternators are not for charging bigger batteries! They are simply there to supply power demands of on board equipment.
