2002 2.5 TDI ACV
Hi all, anyone any experience of this please?
I've been putting off the instillation of the whole leisure system as I've not been able to find an answer to this question hoping that you good folks can help please?
I've a 110 A/H AGM battery that'll be fed via a fused feed from the Durite voltage sensitive relay.
From the leisure battery to a 6way fuse carrier and then on to V basic stuff - Waeco CF25, underseat active sub, a dozen small LEDs, a couple of usb sockets and a 12v cigarette lighter that'll runt a small 350A inverter or a portable dvd player.
At some point I'd like to put a small PV panel on the roof to top up both the batteries when we're parked up.
We don't do many camp sites so have no plans to fit 240v. On the very rare occasions when the stars align, I've charged the leisure battery with a CTEK MXS 5.0
The question is, will the standard alternator regulator/Durite combo do all the funky stuff that I don't understand but that AGM's seem to need, or do I need to install a DC to DC charger between the vsr and the leisure battery?
Is there a charge controller that'll deal with a feed from the vsr and a PV panel?
Any thoughts or experience gratefully received. TIA
T
T
